Capability & Plant List
5 AXIS PRECISION WATERJET MACHINING
Two 5 axis precision Water Jet CNC. At present we can cut almost any material (except laminated glass) to a honeycomb structure with a tolerance of .003 - .005”. Machines have a tilt jet which allows cutting to 6”-8” deep with no taper (the displacement of water is transferred into the waste material). These machines can cut tufnol/plastics with no delamination and are the only machines in the UK with a CNC drill attachment.
PUNCHING
Pullmax Pullmatic 126 CNC Punch Press complete with 2D & 3D Design and Programme facility.
Boschert Corner Notching Machine.
Thirteen Deep Throat Fly Presses with Full Tooling.
All work is carried out by our highly experienced specialist sheet metal, extrusion and fabrication staff.
GUILLOTINE
Safan 2.5 mtr. (max. 4mm capacity).
FORMING
Safan 2.5 mtr. 80 Tonne Brake Press.
Hydraulic Fly Press 8 Tonne.
Armada 50 Tonne Brake Press.
TURNING
Mori Seiki NL 2500/1250 (2 x Live Tooling).
Mori Seiki NL 2500/750 (2 x Live Tooling).
Emoturn CNC 220 Lathe with Hydrofeed.
Glidemaster CT40.
Ecocael 461e. 40 cm Dia Max.
MILLING (17 VMC's)
Mikron HPM 600U (Fully simultaneous 5 Axis CNC).
Mikron UCP 600 (7 Station Pallet Change 5 Axis CNC).
Mikron VCE 1200 (4 Axis CNC).
Mikron VCE 1100 (3 Axis CNC).
Mikron VCE 1000 (3 Axis CNC).
Mikron VCE ProX 800 (3 Axis dedicated for Plastics only CNCs) x 2.
Mikron VCE ProX 800 (3 Axis CNCs) x 2.
Mikron VCE Pro 800 (3 Axis CNCs) x 3.
Bridgeport VMC 800 (3 Axis CNCs) x 2.
Bridgeport VMC 600 (3 Axis CNC).
Europa 2000s (Semi CNCs) x 2.
WELDING
Miller Aerowave Tig Welder AC/DC.
Cebora Welding Plant Tig Star AC/DC.
SureWeld Spot Welder.
Butters Mig Welding Plants.
Cebora Plasma Cutter.
Oxyacetylene Plant.
Miller AeroWave Tig Welder AC/DC x 2.
PAINT SHOP
Water Wash Spray Booth.
QUALITY CONTROL
Granite Worksurfaces.
Trimos Digital Height Gauges.
Inspection Grade Slip Gauges.
CMM Mitutoyo Crysta M 574.
ANCILLARY
Pillar Drills.
Senator Horizontal Band Saw.
Pedrazzoli Circular Saw.
Electric Fork Truck.
Neederman Extractor Plant.
Jones Shipman Surface Grinder.
Vanco Linisher.
Rumblers (Tumble type) De-burring.
VAC Blasting.
Nadcap Welding Adcrediatation...ISO 9001:2000 AS9100...SBAC A|D|S
